Extrude polygon to heights
  • Sep 25, 2018 11:02 PM UTC
  • 79 views
A 2D-polygon that i want to extrude to a max height that I've calculated with a statistic calculator. Now i want to add the attribute with the height I've calculated to the 2D-polygon so i can use it as teh vertica ldistance to extrude withe the extrude transformer.
How can I add an attribute with a attribute value to a polygon?
Best answer by takashi
Hi @hadhafang, if you are looking for a way to merge an attribute storing the max height value to a polygon feature unconditionally, the FeatureMerger could help you.
  • Send the polygon feature to the Requestor port,
  • send the feature having the max height attribute to the Supplier port,
  • and set an identical constant value (e.g. 1) to the Join On for both Requestor and Supplier.
  • Sep 26, 2018 3:22 AM UTC
  • Sep 27, 2018 5:26 PM UTC
Thank you @takashi
