Extraction of EXACT points (XYZ Excel File) that intersect / are completely within 3D Cube (IFC File)
  • May 16, 2024 3:52 PM UTC
  • 130 views
vimva679
Forum|alt.badge.img+11
Am sure am missing out some step or obtain right setting. I am trying to extract points that fall inside or intersect 3D Cube .
I am also getting points as an output that are not within 3D Cube .
Please note: 3D is cube is multi-surface with different shapes and its IFC file.  I shall be highly obliged with FME Community expert to help me with their know-how and expertise to bridge that missing part / thank you for support and time.
daveatsafe
Forum|alt.badge.img+24
  • May 16, 2024 4:44 PM UTC
Hi @vimva679,
The SpatialFilter is currently 2D only - it does not use Z for its filtering. Please try using the Clipper instead, which will separate the inside and outside points when using solid geometry as a clipper feature.
vimva679
  • May 17, 2024 8:40 AM UTC
thank you @daveatsafe likewise always. Will try that and see how it goes.
