Extracting values from JSON objects in JSONTemplater
  • Jan 16, 2026 4:48 PM UTC
  • 6 replies
  • 149 views
bruceharold
Forum|alt.badge.img+20
I’m having trouble finding examples for JSONTemplater when working with a JSON array input attribute.
The incoming data looks like this:
{"layers": [
"defaultVisibility": true,
"geometryType": "esriGeometryPolygon",
"id": 1,
"maxScale": 0,
"minScale": 0,
"name": "Parcels",
"parentLayerId": -1,
"subLayerIds": null,
"type": "Feature Layer"
I’m interested in extracting the first array member id value into an object like this:
{"layers": [{"id": 1}]}
I can almost get the data into what I want in two steps, first extracting the value with a query json["layers"][0]["id"] and then using the JSONTemplater to use the id value, but bizarrely the value 1 is cast to string “1” byt the templater, which is invalid for downstream work.
Anyone know how to make what I want in one step with JSONTemplater?  Thanks.
Best answer by debbiatsafe
Hello ​@bruceharold,
You can use the following template in the JSONTemplater given the incoming JSON data is stored in an attribute named input:
"layers" : [
let $firstArrObj := fme:get-json-attribute("input")("layers")(1)
return {"id": $firstArrObj("id")}
"exportContingentValues":true
This should produce the output you want using only the JSONTemplater.
Forum|alt.badge.img+54
  • Jan 16, 2026 5:18 PM UTC
I don’t know the answer to your first question but if you don’t want quotes in the json templater you can do something like this
xs:int(fme:get-attribute("id"))
cfvonner
Forum|alt.badge.img+32
  • Jan 16, 2026 5:21 PM UTC
​@bruceharold Can you share what you have in the JSONTemplater?
bruceharold
  • Jan 16, 2026 5:22 PM UTC
Thank you!  As the JSON I want is very simple I’m using JSONExtractor and ExpressionEvaluator to get what I need but it would be good to find the canonical way.
bruceharold
  • Jan 16, 2026 5:24 PM UTC
I’ve temporarily abandoned a JSONTemplater but it was (after extracting the id value into it’s own attribute):
  "layers": [{"id": fme:get-attribute("layerId")}],
debbiatsafe
Forum|alt.badge.img+24
  • Jan 19, 2026 10:53 PM UTC
"layers" : [
bruceharold
  • Jan 20, 2026 7:56 PM UTC
Thanks Debbie, but if I had to guess I would say the number of people who could get there from the doc is vanishingly small! 😉This might be a good place for some AI assistance if enough XQuery material is out on the web.
