Extracting nested object with JSONExtractor, issue with booleans?
  • Apr 23, 2019 12:57 PM UTC
  • 223 views
thijsknapen
Forum|alt.badge.img+12
Hi folks,
While I was extracting a nested JSON object using the JSONExtractor, it seemed like I stumbled upon an issue. Consider the following JSON:
    "integer_0": 2019,
    "string_0": "hello",
    "boolean_0": false,
    "nested_item": {
        "integer_1": 2020,
        "string_1": "bye",
        "boolean_1": true
When I use the JSONExtractor with target attribute 'boolean_0' and JSON Query 'json["boolean_0"]', it creates an attribute 'boolean_0' with value 'false'. So far so good.
If I however use the JSONExtractor with target attribute 'nested_item' and JSON Query 'json["nested_item"]', it creates an attribute 'nested_item' with value:
    "integer_1": 2020,
    "string_1": "bye",
    "boolean_1": 1
In this case it thus seems that the boolean value of the json object 'boolean_1' is converted from 'true' to '1'. When using the JSONFragmenter I don't experience this automatic conversion.
Am I overlooking something and is this intended behaviour for the JSONExtractor, or is this some kind of bug?
Thoughts on the matter are appreciated.
Kind regards,
Thijs
ps. attached is a workspace that illustrates the issue:
Best answer by debbiatsafe
Hi @thijsknapen and @offermann82
I'm pleased to say this issue has been fixed in the latest released build of FME 2019.0 and FME 2019.1 betas. You can access the installers at www.safe.com/downloads Thanks!
offermann82
I just stumbled on this issue while migrating an old workspace from FME 2014 to 2018.1.2 and can confirm this behavior. Looks like a software bug to me.
debbiatsafe
Forum|alt.badge.img+24
I'm sorry you ran into this issue. I was able to reproduce the behaviour reported in 2018.x, 2019.0, 2019.1 and have filed a bug report tracking this issue.
Once the issue has been resolved, I will post an update to this Forum post.
debbiatsafe
  • May 23, 2019 9:27 PM UTC
thijsknapen
  • May 24, 2019 8:37 AM UTC
Great to hear :)
