Extracting geometry from SQL Reader
  • Mar 8, 2021 4:31 PM UTC
  • 5 replies
  • 302 views
I have an SQL reader the loads json and a geometry from a postgis table
SELECT $SQL$@Value(schema)$SQL$ AS schema,
       attributes,
       wkb_geometry
FROM @Value(schema).features_addresses
I have to do this as the database connection is dynamic as is the schema and cannot be fixed in a Reader.
My question is how do I extract the geometry as an FME geometry so it can be passed to a FeatureWriter?
I tried using a GeometryReplacer and WKB format but FME rejects the WKB even though it is valid?
Screenshot 2021-03-08 at 16.30.25
Best answer by david_r
 SELECT '0101000020E61000000C3C69A7CF178E3FF54274395CBF4940'::GEOMETRY works fine.
Postgis stores geometries natively as wkb
I agree with @ebygomm​ , I also suspect that it's the datatype. If you look at the ST_AsEWKB() function in PostGIS, it returns a bytea column, not a geometry or varchar-style column. If you do the same thing it should work in FME.
Suggestion:
           attributes,
           ST_AsEWKB(wkb_geometry) as wkb_geometry
  • Mar 8, 2021 4:36 PM UTC
I use that technique all the time and I've never had any problems with it. How do you know that the WKB is valid? What datatype is the column "wkb_geometry"?
  • Mar 8, 2021 4:38 PM UTC
Forum|alt.badge.img+54
  • Mar 8, 2021 6:31 PM UTC
I think the issue is the datatype of the column, try putting a BinaryDecoder in to get the attribute containing the geometry to be encoded as fme-binary before sending it into the GeometryReplacer
Capture
  • Mar 9, 2021 7:18 AM UTC
Suggestion:
           attributes,
  • Mar 9, 2021 8:51 AM UTC
Thanks for the help.. I fixed it with a CAST in the SQL
       attributes,
       ST_ASEWKB(wkb_geometry) AS wkb_geometry
