Extract z-values from TIN to points
  • December 15, 2015
  • 109 views
I'm trying to extract z-values from a TIN surface to points where they intersect the TIN surface. This is a simple process in ArcGIS but I'm just wondering if there's a way to due it in FME without calling ARCGIS tools in my workbench.
Thanks
Best answer by jdh
Sounds like a good candidate for the SurfaceDraper. Your TIN goes into the Points/Lines port and the Points of interest to the DrapeFeatures.
jdh
Forum|alt.badge.img+28
  • December 15, 2015
  • December 15, 2015
Awesome thank you
