Extract values from a complex json file
  • May 29, 2019 10:26 AM UTC
  • 221 views
mda
Forum|alt.badge.img+7
@takashi
I am getting a json file out of a http call. This json is very big and there are many nested values. I need to get some certain values from this json. For example, I need to get the "OTXMP_GPSLatitude". This GPS latitude value is existing many times in the json. I tried to extract this value using many json extraction querys but I get an empty attribute. Some of the json querys I used are : (json["data"]["regions"][*]["OTXMP_GPSLongitude"], or json[*]["OTXMP_GPSLatitude"]). I will attach the json file. I hope that someone can help me getting all the coordinates from this json by one request or json extraction.
Thanks in advance,
  • May 29, 2019 2:07 PM UTC
I think you can use the JSONFragmenter with this query expression to extract every "regions" object as JSON fragment,
json["results"][*]["data"]["regions"]
then use the JSONExtractor with these expressions extract latitude/longitude from each fragment.
json["OTXMP_GPSLatitude"]
json["OTXMP_GPSLongitude"]
mda
  • May 29, 2019 2:34 PM UTC
Thanks a lot @takashi. I was mistaken by the place of [*]. Your solution works good. :)
Regards,,
Muhammed
danilo_fme
Forum|alt.badge.img+58
  • May 29, 2019 2:36 PM UTC
Nice Job @takashi
mda
  • May 29, 2019 2:41 PM UTC
@takashi After knowing the right place for the [*], now I can get the specific values I need directly from the jsonExtractor without using jsonFragmenter for example by using the following query expression
json["results"][*]["data"]["regions"]["OTXMP_GPSLatitude"]
or using a similar expression to extract the ids as following:
json["results"][*]["data"]["properties"]["id"]
Thanks again Takashi :)
Regards,,
Muhammed
