Extract specific part of aggregate by index
jdh
Forum|alt.badge.img+41
Is there a way to extract a specific part of an aggregate by it's index other than deaggregating and testing the resulting features to find the one where _part_number = index.
I'm thinking there might be a way to use XQuery/GeometryPartExtractor
todd_davis
Forum|alt.badge.img+23
  • December 13, 2016
Not really an answer as its just a different way of doing it, but what about using the GeometryExtractor to record the geometry as an attribute,before the aggregation (assuming you are doing this in a step prior) and then just using a ListIndexer and a GeometryReplacer to get the specific geometry you want.
jdh
  • December 13, 2016
I have done that in the past, when I was creating the aggregate at a prior stage in the workflow.
In this particular case, the data input is already aggregated.
  • December 13, 2016
Hi @jdh, yes, you can use the GeometryPartExtractor (Advanced Editor). This is a possible syntax if the input geometry is a one level aggregate or a Multi geometry. Just be aware that a part of the aggregate has to be specified with 1-based index.
(: extract the 2nd part from a one level aggregate or a multi :)
number(/geometry/geometry[2]/@fme_id)
jdh
  • December 14, 2016
Thank you.   That's exactly what I needed.
jdh
  • December 14, 2016
Minor issue with the advanced editor, when you reference a feature attribute using the left panel it does not wrap the attribute name in quotes as required.
{fme:get-attribute(x)}  instead of {fme:get-attribute("x")}
  • December 14, 2016
yeah, have to say it's a kind of bug. @daleatsafe, please fix it.
fmelizard
Forum|alt.badge.img+22
Seems like a quick fix...thanks for pointing it out.
jdh
  • December 14, 2016
There should be a case for it, as I pointed it out to support this morning.
fmelizard
And the fix is going in as I type this. Wish everything was that easy.... Thanks for pointing it out.
brianatsafe
Forum|alt.badge.img+13
Quick update, the fix is available in the latest FME 2017 beta (b17212+).
