Extract pixel values from raster
  • April 24, 2018
  • 7 replies
  • 937 views
felipeverdu
Forum|alt.badge.img+11
I would like to use the pixel values from a raster to proceed with different kind of analysis without converting to vector data. As you can see in the screenshot, in this case is the value from Band 0 (INT32) such as 50.
Best regards,
Felipe Verdú
danilo_fme
Forum|alt.badge.img+53
  • April 24, 2018
Hi @felipeverdu1
I believe you can use the transformer RasterCellCoercer and its possible to choose the point geometry.
Thanks,
Danilo
danilo_fme
  • April 24, 2018
There is a similar question here: Extract Pixel from Raster
gio
Forum|alt.badge.img+15
  • April 24, 2018
@felipeverdu1
You can create a point, offset or affine it by values like target_row,target_col. Using of course the raster extents (lower left corner for instance) and then use a PointOnRasterValueExtractor to extract the values at the target location.
gio
  • April 24, 2018
pixel-value-extraction.fmw
@felipeverdu1
You can of course control the point creation any which way you like.
Still, GDAL or PIL (for python) can do pixel-targeting without having to create geometry first.
felipeverdu
  • April 25, 2018
@felipeverdu1
Thank you so much, gio! I am going to try this out.
felipeverdu
  • April 25, 2018
@gio and @danilo_fme: First of all, thans for your comments. I prefer not to use vector data but raster data since this is more effective and practical in my workflow. It is like in ArcGIS/Python using raster directly.
felipeverdu
  • April 25, 2018
Hi
I solved this thing using a RasterExpressionEvaluator. It was my little knowledge of implementing if statements in the expression evaluator what hinder my understanding. Thanks, @danilo_fme
