Extract pixel values from raster
  • Apr 24, 2018 2:34 PM UTC
  • 7 replies
  • 1108 views
felipeverdu
Forum|alt.badge.img+12
I would like to use the pixel values from a raster to proceed with different kind of analysis without converting to vector data. As you can see in the screenshot, in this case is the value from Band 0 (INT32) such as 50.
Best regards,
Felipe Verdú
danilo_fme
Forum|alt.badge.img+58
  • Apr 24, 2018 2:44 PM UTC
Hi @felipeverdu1
I believe you can use the transformer RasterCellCoercer and its possible to choose the point geometry.
Thanks,
Danilo
danilo_fme
  • Apr 24, 2018 2:47 PM UTC
There is a similar question here: Extract Pixel from Raster
gio
Forum|alt.badge.img+15
  • Apr 24, 2018 3:57 PM UTC
@felipeverdu1
You can create a point, offset or affine it by values like target_row,target_col. Using of course the raster extents (lower left corner for instance) and then use a PointOnRasterValueExtractor to extract the values at the target location.
gio
  • Apr 24, 2018 4:13 PM UTC
pixel-value-extraction.fmw
@felipeverdu1
You can of course control the point creation any which way you like.
Still, GDAL or PIL (for python) can do pixel-targeting without having to create geometry first.
felipeverdu
  • Apr 25, 2018 5:30 AM UTC
@felipeverdu1
Thank you so much, gio! I am going to try this out.
felipeverdu
  • Apr 25, 2018 5:46 AM UTC
@gio and @danilo_fme: First of all, thans for your comments. I prefer not to use vector data but raster data since this is more effective and practical in my workflow. It is like in ArcGIS/Python using raster directly.
felipeverdu
  • Apr 25, 2018 6:23 AM UTC
Hi
I solved this thing using a RasterExpressionEvaluator. It was my little knowledge of implementing if statements in the expression evaluator what hinder my understanding. Thanks, @danilo_fme
