Extract line segment between two points
  • January 21, 2016
  • 133 views
Hi All
I have a spreadsheet with a start and end point for various road sections, and I'm trying to extract the road segments between the start and end points from another spatial data sets containing the road geometry.
SECTIONFROM LATFROM LONGTO LATTO LONGA-33.942151.158-33.935151.143B-33.927151.159-33.940151.146---------------
For example, for road
erik_jan
Forum|alt.badge.img+26
  • January 21, 2016
Did you have a look at the ShortestPathFinder transformer. You will need to create a line using start- and endpoint, but you can use the 2DPointConnector to do that.
Forum|alt.badge.img+7
gio
Forum|alt.badge.img+15
  • January 22, 2016
neighbourfinder to get _closest vertex for the start and ends. (as the points don't seem to coincide with the lines)
Then a snipper using the _closest x and y's.
..just one of multiple way's to do it
jpvo
  • January 22, 2016
But then you would need 2 LengthToPointCalculator using the closestBasex/y for each of the 2 points along the line. Effectively you need a"from / to"distance for your snipper.
