Extract file properties without reading it
  • Jun 14, 2022 9:51 AM UTC
  • 9 replies
  • 304 views
alc33
Forum|alt.badge.img+14
Hi!
I have a lot of pictures and I would like to extract the date of creation.
But when I use the Reader it's too long.
So I tried with PathReader, but if I do that, the properties of the pictures are not avalables.
Does someone knows how to do that?
Thanks !!!
danilo_fme
Forum|alt.badge.img+58
  • Jun 14, 2022 12:52 PM UTC
Hi @alc33​
I suggest you to use the Directory and File Pathnames.
This Reader will bring a lot of informations (metadata) from your readers.
Thanks in Advance,
Danilo
Forum|alt.badge.img+54
  • Jun 14, 2022 1:04 PM UTC
With the pathreader you need to ensure the Retrieve file properties parameter is set to Yes
alc33
  • Jun 14, 2022 1:11 PM UTC
thanks @ebygomm​ and @danilo_fme​ for these answers.
My problem is that with this method, I don't have the properties of the pictures. I have only the properties of the path.
With an AttributeExposer, I also can't find the attributes I'm looking for.
I would like to have the same attributes that I see when I use a Reader of JPG.
  • Jun 14, 2022 1:41 PM UTC
Are you actually looking for exif data?
alc33
  • Jun 14, 2022 1:48 PM UTC
@ebygomm​ yes 🙂
  • Jun 14, 2022 1:56 PM UTC
@ebygomm​ yes 🙂
There is a custom transformer ExifReader
It's not something I've used myself
https://hub.safe.com/publishers/jamess/transformers/exifreader
alc33
  • Jun 14, 2022 2:48 PM UTC
thanks @ebygomm​
I just tried, but I don't understand, it doesn't work...
Does it exist the same with windows parameters ? because I juste need the date of creation of the file. Maybe it's more easy to extract?
Forum|alt.badge.img+63
thanks @ebygomm​
The PATH reader, with the option of retrieving file properties, should read the file creation date. What other properties are you hoping to extract?
alc33
  • Jun 15, 2022 10:28 AM UTC
hi !
I'm looking for the date the photo was taken.
On the "path_modified_date" it seams to be the same, so I will take it. It's more easy for me because my pictures was not modified.
But I think if the file is modified, it's necessary to use ExifReader.
"path_created_date" don't works because it's the date of copy/paste of the file in the folder.
Thanks for everyone for yours answers, I have all I need now 😊
Bye !
