Extract domain value from GDB file?
Hello everyone,
I'm looking for an easy way to extract domain value from a gdb for validation.
I know that you can use ArcGIS Pro to export a XML schema from a GDB, but I want to skip that step.
I tried to use Schema Reader, but it doesn't give me the full domain values in the attributs.
Anyone have an idea ?
Thanks
Best answer by ebygomm
ebygomm wrote:
It's also possible to use arcpy in a python caller to generate the xml if you don't want that step.
I can probably find a working example if interested
So this is the sort of workflow I've used previouslyimageIt takes a GDB location, generates an xml file saved in a temp location then reads in the domain values in that file and processes them into features
import fme
import fmeobjects
import arcpy
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self, feature):
        in_data = feature.getAttribute('input_GDB')
        out_file = feature.getAttribute('temppath')
        export_option = 'SCHEMA_ONLY'
        storage_type = 'NORMALIZED'
        export_metadata = 'NO_METADATA'
        # Execute ExportXMLWorkspaceDocument
        arcpy.ExportXMLWorkspaceDocument_management(in_data, out_file, export_option, storage_type, export_metadata)
        self.pyoutput(feature)
    def close(self):
        pass
 The FeatureReader is a bit of a pain to setup, as you need to point it to an already created xml file first, before you can swap to use the temp path name.
hkingsbury
Forum|alt.badge.img+55
  • August 14, 2022
You'll need to use some python to extract the domain values - https://pro.arcgis.com/en/pro-app/2.8/arcpy/data-access/listdomains.htm
nielsgerrits
Forum|alt.badge.img+54
This could be done using FME in 2019 but this does not work anymore so Python is the way to go. I'm by no means an expert but this works for me.
import fme
import fmeobjects
import arcpy
def processFeature(feature):
    pass
    def __init__(self):
        pass
    def input(self,feature):
        print("TEST TEST")
        domains = arcpy.da.ListDomains("C:/Temp/test.gdb")
        for domain in domains:
            print('Domain name: {0}'.format(domain.name))
            if domain.domainType == 'CodedValue':
                coded_values = domain.codedValues
                for val, desc in coded_values.items():
                    #create a feature for each coded value
                    newFeature = fmeobjects.FMEFeature()
                    #create attribute DomainName
                    newFeature.setAttribute('DomainName',domain.name)
                    #create attribute DomainType
                    newFeature.setAttribute('DomainType',"CodedValue")
                    #create attribute DomainCode
                    newFeature.setAttribute('DomainCode',val)
                    #create attribute DomainDescription
                    newFeature.setAttribute('DomainDescription',desc)
                    #output each feature
                    self.pyoutput(newFeature)
            elif domain.domainType == 'Range':
                #create a feature for each minimum range value
                newFeature.setAttribute('DomainType',"Range")
                print(domain.range[0])
                #create attribute RangeMin
                newFeature.setAttribute('RangeMin',domain.range[0])
                #create attribute RangeMax
                newFeature.setAttribute('RangeMax',domain.range[1])
    def close(self):
        pass
  • August 15, 2022
import fme
import fmeobjects
import arcpy
    pass
    def __init__(self):
        pass
        print("TEST TEST")
    def close(self):
        pass
Thank you very much @nielsgerrits​  I'll try it. You are being very helpful.
  • August 15, 2022
Thank you @hkingsbury​  I'll have a look at the article.
  • August 15, 2022
@Anh Phuong Tran​ If you can tolerate step of exporting the Esri Geodatabase XML Workspace document (Schema Only) using Esri ArcCatalog, as described here ,then this article has the FME workspace configured with the XML reader
Forum|alt.badge.img+39
  • August 15, 2022
  • August 15, 2022
Yes, I would like to know about that example as well. Will make better automation.
Thanks in advance @ebygomm​
  • August 16, 2022
import fme
import fmeobjects
import arcpy
    def __init__(self):
        pass
    def close(self):
        pass
  • August 16, 2022
Python to extract domain values for use in FME - (I've always used the xml method as often when performing validation there are a number of other things I check from the xml as well so not sure whether this code will cover everything)
import fme
import fmeobjects
import arcpy
    def __init__(self):
        pass
        self.domains = arcpy.da.ListDomains(feature.getAttribute('input_GDB'))
    def close(self):
        for domain in self.domains:
                    feature = fmeobjects.FMEFeature()
                    feature.setAttribute("DomainName",domain.name)
                    feature.setAttribute("DomainType",'CodedValue')
                    feature.setAttribute("val",val)
                    feature.setAttribute("desc",desc)
                    feature.setAttribute("DomainType",'Range')
                    feature.setAttribute("minrange",domain.range[0])
                    feature.setAttribute("maxrange",domain.range[1])
  • August 16, 2022
Perfect, this should work nicely.
Thank you @ebygomm​ for helping me. It is much appreciated.
