Extract Coordinates using Regular Expression
  • Jul 26, 2018 9:25 PM UTC
  • 355 views
kieranodonnell
Participant
Hi all,
I'm very new to regular expressions but need to use one to extract coordinates from a single field into their individual elements.
The number of characters varies for each feature, so I can't use a substring extractor.
Essentially I want a regex to extract the first coordinate in the brackets, and the second as their own attributes.
Some examples:
POINT (1764887.456903827 5905612.28425431)
POINT (1749937.56 5913840.62)
Where I want separate attributes:
X: 1764887.456903827
Y: 5905612.28425431
Many thanks,
Kieran
Hi @kieranodonnell
I am not to familiar with regular expressions myself but I think this would work (although it may not be the cleanest regex ever):
\d{2,}.\d{2,}
\d = any digit and {2,} = 2 or more of \d
I don't believe you can use regex in a substring extractor so instead I would suggest using a string searcher and writing the matched attributes out into a list.
Then in an Attribute Manager or Attribute Creator you can assign list(0) to X and list(1) to Y.
This regex worked for both examples so should do the trick!
Hi @kieranodonnell
\d{2,}.\d{2,}
PS. There are lots of good online tools to test a regex string and breakdown what each component is selecting to help when you are learning! e.g. https://regex101.com/
kieranodonnell
Participant
Hi @kieranodonnell
\d{2,}.\d{2,}
Thanks @hollyatsafe this is exactly what I was after.
Much appreciated!
Forum|alt.badge.img+54
  • Jul 27, 2018 8:18 AM UTC
It looks like your geometries are well known text, so you could also use a GeometryReplacer followed by a CoordinateExtractor to get your x y attributes.
