Extract attributes and value from XML
  • Nov 28, 2018 3:06 PM UTC
  • 6 replies
  • 95 views
boubcher
Forum|alt.badge.img+11
we use An API call in order to get information from a GIS app, the response we get is an XML,
we want to convert to attribute
I used the many of the transformers there but didn't get the expected result
how we could extract all the attributes from the XML and their value
this is the XML we are getting from the rest API response we get
danilo_fme
Forum|alt.badge.img+58
  • Nov 28, 2018 3:26 PM UTC
Hi @boubcher
Could you save this file with xml extension and structure xml?
Thanks,
Danilo
boubcher
  • Nov 28, 2018 3:35 PM UTC
boubcher
Hi @boubcher
Thanks,
Danilo
sure just added the file data
danilo_fme
  • Nov 28, 2018 3:52 PM UTC
@boubcher Thanks your data.
I received your data and changed it incluiding in the end this xml the tag <\\layers>.
After I read this file in Workbench.
Thanks,
Danilo
boubcher
  • Nov 28, 2018 5:12 PM UTC
Thanks,
Danilo
@danilo_fme
did you use a simple XML reader or XML Flatnner , could you please share the WS ,
danilo_fme
  • Nov 29, 2018 7:27 PM UTC
@danilo_fme
I used the Reader XML - Parameters - Elements to Match
Thanks,
Danilo
