External Python script
  • Jan 28, 2020 10:03 PM UTC
  • 214 views
Hi there,
Need a suggestion from FME's experts. I have FME transformation that calculates two fields based on the data coming from different sources. Now, I want to use the calculated field along with some other fields from the data and perform normalization on it. I have already written a script in Python (separately) which performs normalization. The Python scripts contains while loop and comparison operators. Is there any way of calling the external Python script from FME? What do you suggest
Best answer by warrendev
You can use the python caller transformer if it's during a translation. There is also python startup and shutdown scripts you can run as well. Here is some helpful information.
FME and Python
https://knowledge.safe.com/articles/706/python-and-fme-basics.html
FME Python API
http://docs.safe.com/fme/html/fmepython/
Python Caller
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/pythoncaller.htm
warrendev
Forum|alt.badge.img+28
  • Jan 28, 2020 11:57 PM UTC
FME and Python
FME Python API
Python Caller
