ExpressionEvaluator vs. AttributeManager
  • March 10, 2017
  • 7 replies
  • 95 views
Hi folks,
I have a an expression that works beautifully in the ExpressionEvaluator. I was hoping to use this in he AttributeManager as I wanted to do a similar thing to many fields and use conditionals, I tried many things and the expression never seems to work out with AttributeManager.
((@Value(SCORE)/20)*@Value(LOADING))+@Value(SCORE)
I tried changing to @div, @mult, and @add maths functions but they didn't get me any closer to the action
where am I going wrong :S
Thanks in advance!
Best answer by redgeographics
If it works in the ExpressionEvaluator it should also work in the AttributeManager.
One thing you can check is whether or not you have entered this in the AttributeManager's arithmetic editor (which mimics the ExpressionEvaluator) or the text editor, in which case you'll get a text string as result... (I know I often make that mistake myself).
If that's not it, I'd like to know what kind of error message you're getting.
Forum|alt.badge.img+63
Forum|alt.badge.img+51
  • March 10, 2017
Yes, I could really use a little message that says
"It looks like you've entered an arithmetic expression in the text editor, do you really mean to do this"
itay
Forum|alt.badge.img+19
  • March 10, 2017
and in addition to that automagically add the @Evaluate() function :)
  • March 10, 2017
Ok i'm still a bit confused, my expression is:
which should work right? It appeared to wrok in my ExpressionEvaluator
Now I'm getting this error:
Is there some trick I'm missing?
I've re-wrote and tried the expression in multiple ways, but alas no success. I tried evaluating the variable before the AttributeManager, no luck with that.
  • March 10, 2017
It looks like you might have a similar error in an earlier transformer where you create the SCORE attribute. It looks like instead of being a number, SCORE is set as 42*1.0/1.0
  • March 10, 2017
Good idea, I'll check my previous transformers and report back!
  • March 10, 2017
I can confirm it all works as expected! Now time for me to leave the office, thanks @redgeographics and @egomm :)
