Expresion with function in XMLTemplater for recursive loop for nested xml?
  • May 28, 2019 2:47 PM UTC
  • 117 views
I have a simple list n=74 codes which I read using the regular ROOT and SUB template expression: {fme:get-attribute("code")} but because of a nested comparison, they are nested as shown below. I get errors for the missing closing tags (</inv:And>) and If I pre-fill the closing tags, I get an error because they do not match the opening tags.
This is perfect for a recursive loop, but a function would be needed within the xmlTemplater? or a script? or 2 loops one for the top half and another for the bottom half? Below is the end result (partial code) of the desired end result. I can manually add the last code <code>code n</code>. The rest is symmetrical. FME desktop 2018.
Addition: terribly sorry I did not mention that code is a string.
Best answer by takashi
If I understand your requirement correctly, this expression would work as desired.
declare namespace inv="replace/this/with/actual/namespace.name";
let $i := xs:integer(fme:get-attribute("num"))
return
<inv:And>
    <inv:code>{fme:get-attribute("code")}</inv:code>
    {fme:process-features("SUB", "num", $i+1)}
</inv:And>
  • May 28, 2019 11:32 PM UTC
If you have n input features with "code" attribute containing 1-n, this workflow might help you. Assuming that the code of the first feature is 1.
XML Template Expression (common to both Root and SUB)
let $i := xs:integer(fme:get-attribute("code"))
return
<inv:And>
    <code>code {$i}</code>
    {fme:process-features("SUB", "code", $i+1)}
</inv:And>
  • May 31, 2019 11:26 AM UTC
@takashi
Dear Mr. Takashi, thank you for your advise. I am sorry I did not clarify that code is a string, but, I added a num column to the data and tried what is below in both Root and SUB expressions. I get the error below, and cannot see why as it is declared. So with num as an integer (1 to 74), code as a string, e.g, 333-22-2,5, and both columns in a spreadsheet, the following expression
declare namespace inv="<http://etc, etc/inv>";
let $code := xs:string(fme:get-attribute("code"))
return
<inv:And>
<inv:code>{$code}</inv:code>
{fme:process-features("SUB","code",$i+1)}
</inv:And>
gives me these error messages:
XMLTemplater_2(XMLTemplaterFactory): "i": undefined undeclared variable
XMLTemplater_2(XMLTemplaterFactory): An error occurred while parsing the ROOT template..
  • May 31, 2019 3:03 PM UTC
return
<inv:And>
</inv:And>
  • May 31, 2019 4:53 PM UTC
return
<inv:And>
</inv:And>
I worked, thank you! :)
