exposing dwf attributes
  • Jan 17, 2019 3:44 PM UTC
  • 9 replies
  • 74 views
I'm trying to migrate from dwf's to GIS. When I inspect the dwf in inspector, none of the attributes that I really need and can see in Autodesks design review are even listed in the available columns under table view schema. Is this a known issue or is this due to my limited experience with FME?
danilo_fme
Forum|alt.badge.img+58
  • Jan 17, 2019 4:00 PM UTC
Hi @larisakruger
Did you enable the Attributes in the Reader? Like this:
Thanks,
Danilo
Yes, all of the attributes are exposed.
When I view the dwf in Autodesk Design Review it recognizes the Space ID for Identity Data, but I do not see SpaceID listed anywhere in the attribute list in FME. Can you help me out?
danilo_fme
  • Jan 20, 2019 1:47 PM UTC
Hi
Could you share this file?
Thanks,
Danilo
gio
Forum|alt.badge.img+15
  • Jan 21, 2019 1:54 PM UTC
@larisakruger
Is it not the attribute "autocad_identity_handle" (that's been named or referred to as Space_id ?)
I loaded some sample dwf, and all attributes are exposed by fme if requested.
Mount Hall01.pdf
I tried viewing the dwf in inspector. I do not see any autocad_identity_handle attribute. I think I have everything exposed. I have also attached the dwf, but I had to change the file type as the dwf was not permitted. You'll have to change the .pdf back to .dwf. Please feel free to take a look at it. Thanks!
andreaatsafe
Forum|alt.badge.img+17
Hi @larisakruger,
Unfortunately reading Object Properties from a DWF file is not currently supported.
I've added this Q&A post to our outstanding issue (FMEENGINE-9609).
- Andrea
Hi @larisakruger,
- Andrea
Thanks for responding Andrea. We have other formats we can use. But dwf would have been a bit more streamlined.
Hi @larisakruger,
- Andrea
We would be interested in getting the object properties supported in FME. Who might I talk to if we were willing to front some capital to get this moved up the priority list/fast tracked?
andreaatsafe
Thanks for your interest in getting this supported @larisakruger
I've passed your note on to our team!
