exposing attribute in square brackets using JSON Fragmenter
  • Apr 11, 2019 10:00 AM UTC
  • 175 views
I'm trying to expose attributes from a JSON file using JSONFragmenter and it's working perfectly fine for all attributes except one which is stored in [] brackets.
This is an example of how the JSON is structured:
[{"id":"5cad42","nummer:"697582","name":"place name","position":[51.51146259999999,11.5696619],"status":false}]
And once I have exposed the attributes I see all values except "position" value is missing, so I assume it has something to do with the [] brackets.
These are the JSONFragmenter Parameters:
Should something be changed here?
I know it must be easy :)
Thank you!
Cheers,Linda
Best answer by david_r
The square brackets in JSON implies an array of values. In FME, these will exit as a list.
In this case the list will be called position{}, and you'll have to expose it manually in the JsonFragmenter.
  • Apr 11, 2019 10:13 AM UTC
  • Apr 11, 2019 11:42 AM UTC
Thanks for the quick answer! Got it :)
