Expose file type of zipped file
  • May 27, 2020 4:06 PM UTC
  • 61 views
pflegpet
Forum|alt.badge.img+8
is there a way to expose the file type suffix (e.g. ".shp") after the file has been created and zipped with the FeatureWriter? The "_dataset" attribute only yealds the .zip suffix whereas _feature_type attribute does only show the file name without the suffix. Thank you for your help.
Best answer by itsmatt
You should be able to configure a PATH reader in a FeatureReader to read the contents of the zip file. See here as an example:
https://knowledge.safe.com/questions/37542/directory-and-file-path-when-reading-a-zip-returns.html
itsmatt
Forum|alt.badge.img+48
  • May 27, 2020 7:45 PM UTC
danilo_fme
Forum|alt.badge.img+58
  • May 27, 2020 11:46 PM UTC
Perfect solution with this transformer @virtualcitymatt
