Expose attribute from feature reader
  • November 27, 2023
  • 332 views
pinkopo
Forum|alt.badge.img+5
Hi guys a silly question here,
is there a way i can expose the attributes before use dynamic schema to write them out? I'm using feature reader to read a list of sde feature class from csv file but hope i can expose their attributes for further processing before write to the destination..
Thanks!
Best answer by j.botterill
Hi pinkopo, on the feature reader, if you go into the parameters of the format that you are reading... nicely hidden is the "schema attributes" where you can add attributes such as fme or format attributes; or manually type in attribute nameschemaattributes_expose
j.botterill
Forum|alt.badge.img+40
  • November 27, 2023
