Exporting geodatabase attachments to JPEG?
  • Nov 28, 2017 2:55 PM UTC
  • 293 views
sofia
Forum|alt.badge.img+5
I would like to export images from a geodatabase attachment table to JPEGs.
In the process I would love to write the geoobject feature attributes to name the jpeg.
The attachments are joined to geoobject features by a Global ID. I would like to name the jpegs with attributes from "Stadsvandring" and "ID_nr" columns.
I appreciate tips on what translators could be used!
/Sofia
Best answer by nielsgerrits
Greetings,
I am exporting data from an ESRI File gdb to DXF files (fanned out).
I would like to update Entity values from a list, rather than opening the DXF in a text editor and manually updating the values.
The format is:
1001
ACAD
1000
type=NT
I want to set the values to:
1001
Trimblearea
1000
dxf name (sourcelayername)
I would appreciate anyone sharing any pointers or a simple workbench, that illustrates this.
Regards,
Clive
danilo_fme
Forum|alt.badge.img+58
  • Nov 28, 2017 6:03 PM UTC
Hi @sofiamvalentin,
How is the structure you Source data Geodatabase? Could you share us a sample of your data?
Thanks,
Danilo
nielsgerrits
Forum|alt.badge.img+67
  • Nov 28, 2017 8:47 PM UTC
Greetings,
The format is:
1001
ACAD
1000
type=NT
1001
Trimblearea
1000
Regards,
Clive
sofia
  • Dec 7, 2017 12:24 PM UTC
Not having Workbench on my current device so no sample but this is quite easy. First of all you need to connect the attachment table to the data. FeatureMerger will do this, primary key in datatable, key in attachment if I recall correctly. Then I use a RasterReplacer to create the image out of the blob. JPEG Writer to write to file, concat the name out of the attributes.
Perfect, FeatureMerger and RasterReplacer worked very well. Thank you so much for the tip!
sofia
  • Dec 7, 2017 12:25 PM UTC
Hi @sofiamvalentin,
Thanks,
Danilo
Thank you for the response, but the featuremerger and rasterreplacer workflow was simple and fast!
