Export as CSV without " "
  • November 15, 2024
  • 6 replies
  • 43 views
fmetutorial
Hello all ! I need to create CSV where value will end  with a semicolon. I can do it using AttributeManager > @SetValue(SUP); but in that case it would add “ “ between attribute because it is converted to varchar. I need it without those “ “ but can’t manage to do it.
Example below : 1st is my output and second is what i want. Only difference is those “ “.
PS : Title is correctly formatted
CODE_AL;NUM_AL;LIBELLELOL;LIBELLEC;SECTSTAT;ANCIENNE_C;NOUVELLE_C;CODE_POSTAL;PRO;REGION;PAYS;POP;SUP
10;10;GEROMPONT Avenue des Déportés 74;GEROMPONT ;25122C11-;Gérompont;Ramillies;1367;Brabant Wallon;Région Wallonne;BELGIQUE;82;"0,099368;"
10;10;GEROMPONT Avenue des Déportés 74;GEROMPONT ;25122C11-;Gérompont;Ramillies;1367;Brabant Wallon;Région Wallonne;BELGIQUE;82;0,099368;
lambertus
Forum|alt.badge.img+16
  • November 15, 2024
@fmetutorial Could you share (part) of the CSV file ?
Forum|alt.badge.img+39
  • November 15, 2024
You should be able to make amendments in the advanced settings to prevent the field being quoted and to allow the ; that is part of the SUP attribute to be written
fmetutorial
  • November 15, 2024
Thans for your answers.
@lambertus , i’ve linked part of my CSV file
@ebygomm , Which transformer are you talking about to access advanced settings ?
Thanks for help !
  • November 15, 2024
The advanced settings are in the csv writer
fmetutorial
  • November 15, 2024
@ebygomm I could not see those options in my writer. Do you mind sharing the whole window instead ?
  • November 15, 2024
