Export ArcFM data to GeoJSON
  • May 14, 2018 3:20 PM UTC
  • 88 views
How to get the Node connectivity or Geometric Network information out of ArcFM. Requirement is to get the data for Electric tracing.
To read Geodatabase network connectivity data, the FME Geodatabase reader has the reader parameters:
   Ignore Network Info: Yes|No  (default is Yes - which is do not read the connectivity )
You might also want to use the parameter:
   Split Complex edges: Yes|No
Setting these parameters will:
  • Add the feature class Net_Junctions which are the network junctions with the following attributes:
geodb_edge_feature_count      2
geodb_element_id              2022
geodb_feature_is_simple       yes
geodb_type                    geodb_simple_junction
  • Add the from_ & to_ attributes to the line feature classes
geodb_element_id 	         7416
geodb_element_index          0
geodb_from_junction_element_id 2022
geodb_to_junction_element_id 5874
geodb_type                 geodb_complex_edge
To read an ArcFM Geodatabase you nede the ArcFM Object reader. Have a look at this article: Reading ArcFM Geodatabase data using FME
