explode the properties of an XML element into attributes
  • Sep 18, 2018 4:16 AM UTC
  • 91 views
kimo
Forum|alt.badge.img+10
I have a bulk soap extract that has a list of assets with attributes as properties, not elements. I cannot find in the many XML transformers what I need to do to get the assets back into a simple table with each property as an attribute.
Here is a snippet of the first two AssetSummary elements.
Best answer by takashi
Hi @kimo, you can use the XMLFragmenter (Elements to Match: AssetSummary, Flatten Options/Enable Flattening: <checked>) to extract every attribute in the AssetSummary element as feature attributes.
Resulting features will have attributes which are named "AssetSummary.<original attribute name>", like this. Just be aware that you will have to expose them if necessary.
  • Sep 18, 2018 6:12 AM UTC
  • Sep 18, 2018 6:16 AM UTC
In addition, you can use the BulkAttributeRenamer (Rename: All Attributes, Action: Remove Prefix String, String: AssetSummary.) to remove the prefix "AssetSummary." from all the attribute names.
kimo
  • Sep 19, 2018 7:21 AM UTC
Yes, did all that. That's the easy part!
