Explode multi-part geometry
Forum|alt.badge.img+49
The attched FFS file contains multi-geometry objects where one or more of the parts are arcs. I need to do some checks on the parts that are not arcs. So far I haven't been succesful in getting only the non-arc segments out, so any suggestions would be very welcome.
I tried the GeometryPartExtractor (checking for child elements of type IFMEArc) but that only selects the entire object, I want to break it up.
And stroking the arcs is not an option...
  • October 5, 2017
Have you tried the PathSplitter and then filter on fme_type = fme_arc
That seems to do the trick, thanks! I was looking for Geometrysomethingsomething...
erik_jan
Forum|alt.badge.img+18
  • October 5, 2017
Or the DeAggregator and then filter on fme_type = fme_arc
  • October 8, 2017
Hi @redgeographics, why not try the GeometryPartExtractor with "This part | Geometry Type | = | IFMEArc"?
  • October 9, 2017
There are no aggregates in his dataset.
  • April 3, 2018
Me too - Geometrysomethingsomething !
  • April 3, 2018
Just for once it was Pathsomethingsomething ;-)
