Explode multi-part geometry
  • Oct 5, 2017 11:06 AM UTC
  • 7 replies
  • 1446 views
Forum|alt.badge.img+63
The attched FFS file contains multi-geometry objects where one or more of the parts are arcs. I need to do some checks on the parts that are not arcs. So far I haven't been succesful in getting only the non-arc segments out, so any suggestions would be very welcome.
I tried the GeometryPartExtractor (checking for child elements of type IFMEArc) but that only selects the entire object, I want to break it up.
And stroking the arcs is not an option...
  • Oct 5, 2017 11:29 AM UTC
Have you tried the PathSplitter and then filter on fme_type = fme_arc
That seems to do the trick, thanks! I was looking for Geometrysomethingsomething...
erik_jan
Forum|alt.badge.img+26
  • Oct 5, 2017 1:14 PM UTC
Or the DeAggregator and then filter on fme_type = fme_arc
  • Oct 8, 2017 7:02 AM UTC
Hi @redgeographics, why not try the GeometryPartExtractor with "This part | Geometry Type | = | IFMEArc"?
  • Oct 9, 2017 6:55 AM UTC
There are no aggregates in his dataset.
  • Apr 3, 2018 2:22 PM UTC
Me too - Geometrysomethingsomething !
  • Apr 3, 2018 2:24 PM UTC
Just for once it was Pathsomethingsomething ;-)
