Explode 3dMesh
  • September 15, 2015
  • 106 views
zzupljanin
Forum|alt.badge.img+5
I'm having data in AutoCAD .dwg format. Is there a way to explode polyfaceMesh (fme_geometry: fme_aggregate, fme_type:fme_surface) to lines?
Thank you for your help
Hi
I'd first try using a DeAggregator to decompose any aggregates and then a GeometryCoercer to convert the individual geometries to fme_line.
David
zzupljanin
yup, I tought that also. Doesn't work since Deaggregator explodes surfaces only to smaller surfaces which are still aggregated.
zzupljanin
  • January 13, 2016
Hi
David
apologies, you were actually right. Thank you.
