Executing SQL Statements in SQL Executor based on condition
  • Nov 15, 2023 9:58 PM UTC
  • 50 views
marsh007
Forum|alt.badge.img+11
I've 6 SQL statements in SQL executor. I'm trying to execute these 6 statements only when name_<1-6> value exists. If any of this value is NULL or missing, then that corresponding SQL statement needs to be skipped to avoid error.
insert into demo.lu_test values (@Value(id), '@Value(name_1)', 1);
insert into demo.lu_test values (@Value(id), '@Value(name_2)', 2);
insert into demo.lu_test values (@Value(id), '@Value(name_3)', 3);
insert into demo.lu_test values (@Value(id), '@Value(name_4)', 4);
insert into demo.lu_test values (@Value(id), '@Value(name_5)', 5);
insert into demo.lu_test values (@Value(id), '@Value(name_6)', 6);
@david_r​ Please suggest. Thanks!
  • Nov 15, 2023 11:28 PM UTC
Hi @fmeuser_gc​ ,
I don't think you can set conditional statements to the SQL Statement parameter in SQLExecutor. Instead, you can create insert statement(s) individually for only valid name_N using some transformers. For example:create-sql-statemtnts
