Excel Writer : Control default sheet
  • May 17, 2023 7:50 AM UTC
  • 328 views
lgrie
Forum|alt.badge.img+8
Hello,
a while ago a user suggested to implement an "Option to control default sheet on Excel writer"
Does anyone know if this is now possible ? I am writing an Excel file with up to 100 sheets and I want to force Excel to open the first sheet by default.
Thanks.
Best answer by nielsgerrits
Thanks for your suggestion, Niels.
What I did not mention is that I am using a FeatureWriter with three different entries:
My first desired sheet is a recap, misting all other sheets, which I create seperately.
Than I have my sheets and the third entrie is a ssheet listing errors occured during the process.
So I am not sure if your suggestion does the trick. But it is a great starting point.
I think it does, sample workspace attached.
nielsgerrits
Forum|alt.badge.img+67
I do not know of an option in the writer. But I believe the last written sheet is the active one. So as a workaround, with AttributeCreators creating an order attribute, a Sorter and an AttributeFilter you can force this.
lgrie
  • May 17, 2023 8:27 AM UTC
nielsgerrits
  • May 17, 2023 8:35 AM UTC
lgrie
  • May 17, 2023 9:14 AM UTC
This worked for me quite well! Bedankt !
