Excel worksheet to Sharepoint > How to hide fields
  • November 20, 2023
  • 124 views
epro_admin
Forum|alt.badge.img+7
Hi there, I have a workspace that fills out an excel spreadsheet and then pushes this into Sharepoint. I want to hide the first five columns in the spreadsheet (so I can unhide them when I need to check, but the user doesn't have to see it). How do I do that?
I tried hiding them in the spreadsheet in Microsoft 365/Excel Online, but they revert to showing every time the process runs.
I tried in the FeatureWriter Paramaters> Edit Column Formatting> Cell Protection> Hidden in the first five columns, but that didn't work.
imageThanks in advance for any guidance you can provide.
Best answer by hkingsbury
I'm guessing the reason why the columns are un-hidden is because you have the writer set to 'overwrite existing file'.
One potential solution would be to use a template file, and in that template you will have the first five columns hidden. When the write writes the data (regardless of the overwrite existing file setting) it will use the template as the starting point (instead of an empty excel doc)
hkingsbury
Forum|alt.badge.img+51
  • November 20, 2023
epro_admin
  • November 23, 2023
Thanks @hkingsbury​ ! I was avoiding using the template file, but have made the switch over, and it's a huge improvement.
