Excel Reader - Incorrect String Length
  • May 27, 2024 1:59 PM UTC
  • 157 views
lance
Forum|alt.badge.img+5
I am using FME Form 2024.0 to read an excel file for processing.  The reader is not determining the correct max length of multiple text fields in the XLSX file.
I have set the max rows to scan to a value larger than the total row but short of manually setting these values I cannot get the reader to detect the correct field length.
The FME Help for the MS Excel Reader states to leave this setting blank to scan all rows but the transformer will not except a blank value.
I also tried to use the FeatureReader rather than a standard Excel Reader with the same results.  I want this to be dynamic as the data being read is variable.  Any suggestions or workarounds?
lambertus
Forum|alt.badge.img+25
  • May 27, 2024 7:09 PM UTC
Hi @lance, does this reader issue influence the resulting data red from Excel into FME?
justinweaver
Forum|alt.badge.img+3
To follow up on the same issue. - Is there a way to manually override the TYPE settings in Bulk? ie from the EXCEL reader - id like to set 20 attributes to the same CHAR length , But at the moment i have to do it manually one by one. Anyone know of a way to do selected list at once?
