Evaluate Attribute Syntax
  • Jun 6, 2019 2:49 AM UTC
  • 7 replies
  • 171 views
deanhowell
Forum|alt.badge.img+24
Hello FME Gurus,
I have a list which contains a known sequence of values that represent different things but are linked.
I have created a list and I am then searching in the list for a specific word, in this case 'PM'
The ID for the PM is located two spots in the list before the word PM.
I am trying to extract the ID from the list dynamically but can't seem to get the syntax correct in Attribute Manager.
@Value(_surveytable{@Evaluate(@sub((_list_index),2))}.autocad_text_string)
Can anyone help is getting the index value syntax correct so I get the value that is located in the index minus 2?
Thanks
Dean
Best answer by takashi
I think this expression works for you if the "_list_index" attribute has a number greater than 1.
@Value(_surveytable{@Evaluate(@Value(_list_index)-2)}.autocad_text_string)
  • Jun 6, 2019 7:50 AM UTC
geolassi
Forum|alt.badge.img+8
  • Jun 6, 2019 7:53 AM UTC
Hi! This would work:
I tested with sub function too, but couldn't get it working inside @Evaluate. No errors, but no result. It might be a bug related to sub, since e.g. max is working just fine inside @Evaluate, and it has a similar syntax.
EDIT: Just noticed Takashi had already posted an answer.
deanhowell
  • Jun 6, 2019 11:36 PM UTC
Thanks @takashi you are a champion :)
deanhowell
  • Jun 6, 2019 11:37 PM UTC
Thanks @geolassi very much appreciated.
deanhowell
  • Jun 7, 2019 1:06 AM UTC
Thanks all, the suggestions above worked but only gave me the first match using List Searcher.
Is there a way to loop through all values in the list?
Forum|alt.badge.img+54
  • Jun 7, 2019 7:17 AM UTC
It seems like you're building the list in the first place - if you just want to keep every feature that is 2 places in front of the feature with the value in PM you could use the adjacent attribute function with a conditional in an attributecreator without building a list
So for each feature, test whether the feature that is 2 after it equals PM. If it does, make a new attribute called PM holding the value in the autocad_text_string.
If there's another reason for using the list and I had to loop through it i'd probably resort to python.
Example:
two_in_front.fmwt
deanhowell
  • Jun 11, 2019 2:44 AM UTC
Example:
two_in_front.fmwt
Thanks @egomm, that worked perfectly after tweaking the index values to get the correct values.
