Extremely new to the FME environment. With 420+ transformers it is hard to know where to begin. I am starting with an ESRI (line) shapefile that contains two attribute columns:
SUBTYPECD (numeric) with values [1,2,3,4,5,6]
VOLTAGECD (numeric) with values [2,20,23]
Using five TESTER transformers I have various combinations of conditions that I am wanting to "route" to five specific layers in an AutoCAD template file. The linetypes and colors are already set in the template. My question is, how does one process the output of a "pass/fail" tester and have it decode into a text string (e.g. "PRIMARY-26KV") that I can then send to the AutoCAD drawing writer?
This process must be also repeated for a myriad of POINT and ANNOTATION objects. Does anyone have a sample model for converting multiple shapefiles (really needs to be SDE, but that is later) into a single AutoCAD template file that has layers, colors, linetypes and block (with attributes) predefined?
Any suggestions would be greatly appreciated.
Lynn
Seattle City Light
