ESRI FileGeoDatabase to FileGeoDatabase Annontation while preserving Font Size using FME
  • Jan 21, 2019 7:26 PM UTC
  • 48 views
I have annotation features in one FileGeoDatabase and I translate them to another FileGeoDatabase using FME. However, it does not maintain the font size. I think it has to do with the relationship of text size and symbol ID in the FileGeoDatabase. But I cannot maintain the font size of the annotation whatever FME format attributes I use in the writer.
trentatsafe
Forum|alt.badge.img+7
Hello @gidolangen,
Just to follow up, I believe you solved this by using the LabelPointReplacer. You might also be able to write the value using the geodb_text_size format attribute on the writer. Although, I believe this will take into account the reference scale as well and as a result could produce different text sizes between source and destination.
Another article that may help is the following: https://knowledge.safe.com/articles/520/setting-font-size-explicitly-in-geodatabase-annota.html
I hope that helps!
