Error when using NeighborFinder Transformer
  • Aug 17, 2018 1:40 PM UTC
  • 6 replies
  • 80 views
pushpa
Forum|alt.badge.img+9
Hi there,
I have a workspcae on FME2018 reading 2 shapefiles one has point geometry (1.7million) one has line geometry (7.5million)
I am trying to find the distance to line geometry and this workspace was working fine until I changed the line Geometry shapefile to ESRI File GeoDatabase.
I have the following error on 220 lines now. what is this mean? Can I ignore this error and use my results?
NeighborFinder(ProximityFactory): Processing 1.09% complete
IFMELine was given an index beyond its current range
... Last line repeated 55 times ...
NeighborFinder(ProximityFactory): Processing 1.1% complete
thanks
Pushpa
  • Aug 17, 2018 1:43 PM UTC
Have you tried running your geometries through a GeometryValidator before the NeighborFinder?
pushpa
  • Aug 17, 2018 2:22 PM UTC
hi,
No issue with the geometry when I run through. I still get the same error
  • Aug 17, 2018 2:25 PM UTC
hi,
Can you isolate which features create the issue? If yes, can you maybe post an FFS dump of a couple of them here?
Forum|alt.badge.img+54
  • Aug 17, 2018 2:33 PM UTC
pushpa
  • Aug 17, 2018 2:40 PM UTC
pushpa
  • Aug 17, 2018 2:42 PM UTC
I dont know which onces creating the issue.
