Error regarding Coordinate systems
  • December 13, 2019
  • 30 views
Hello,
I'm a beginner in FME and I need to run a model that was made by my colleague.
When I run it, I get error message:
CS-MAP Reprojector: User specifed transformation 'SERBIA_to_MONTENEGRO' will be used for 'EPSG:31277mgi' -> 'EPSG:32634'
Geodetic transformation (SERBIA_to_MONTENEGRO) not found in dictionary.
CS-MAP Reprojector: Transformation 'SERBIA_to_MONTENEGRO' could not be loaded
Reprojector: Could not create reprojection engine
Storing feature(s) to FME feature store file `C:\\Users\\dusan\\Desktop\\Transformacija_CG_GK_u_UTM_V1_log.ffs'
As I understand this, I need to configure local coordinate system.
My question is, what files I need to change to have this custom coordinate system in FME?
Thank you in advance!
Marko
erik_jan
Forum|alt.badge.img+19
  • December 13, 2019
Adding custom coordinate systems in FME is described in this article:
Adding_Custom_Coordinate_Systems
Hope this helps.
