EPSG code not written in ECW header correctly
  • Dec 16, 2020 2:57 AM UTC
  • 68 views
nicholas
Forum|alt.badge.img+14
I am running FME(R) 2019.2.3.2 (20200320 - Build 19825 - WIN64)
I am trying to convert a cloud-optimised geotiff into an ecw image (v2)
The image has GDA2020 datum, MGA Zone 56 projection, which is EPSG: 7856
https://epsg.io/7856
The output ecw does not have the correct values for datum & projection in the header. I can use ERDAS Imagine to read the header values
This is the result from FME (as per attached image from_FME.png)
Datum EPSG: 1168
Projection Name SUTM56
EPSG Code 0
To compare, I used ERDAS Imagine to perform the same conversion and these are the header values (as per attached image from_Imagine.png)
Datum GDA2020
Projection Name Transverse Mercator
EPSG Code 7856
I would prefer to use FME as it does bulk translations well. But I need the header information to be correct. How to fix?
hi @nicholas​ - just a thought, but I think FME is not recognising the coordinate system on your data as it is reporting it as EPSG 0. But it looks like EPSG:7856 is in the supported list of CRS/Coordinate system gallery. Have you tried specifying/setting the coordinate system parameter on your Reader and also your Writer rather than using the default <not set> where FME will determine it (but in your case I think FME is unable to determine it).
