Enumerate lines sequence using points enumeration
  • Oct 1, 2025 7:03 AM UTC
  • 64 views
siriosus
Forum|alt.badge.img+4
Hi all,
I’ve successfully solved one issue of enumerating points along the lines (to define flow direction) using this post - Line to connect in order. | Community. Is it possible to enumerate segments of the line the same way using enumeration of points?
crutledge
Forum|alt.badge.img+55
  • Oct 1, 2025 11:45 AM UTC
Hi ​@siriosus You might be able to get away with it very simply by using count and sort for you line features. Hope that helps.
