Encrypt a zipfile
  • Apr 20, 2016 3:27 PM UTC
  • 38 views
nrich_defra
Forum|alt.badge.img+7
We are trying to generate an encrypted zip file containing the output from a workbench.
It seems this isn't as easy as anticipated, does anyone have a solution for this that can be deployed onto FME Server 2015.0?
One option is to have a python shutdown script that calls 7zip, is it possible to install 7zip via the server GUI, in the engine>plugins section for example, and then reference it within the python script?
Regards,
Nick
stalknecht
Forum|alt.badge.img+22
  • Apr 26, 2016 7:57 AM UTC
There is a 7za.exe in <fme server install folder>\\Utilities\\ you can use. You can use a Systemcaller or a Pythonscript to use this one.
