Encoding per dati russi
  • Jul 6, 2018 4:27 PM UTC
  • 68 views
pdorio
Forum|alt.badge.img+8
Ciao a tutti. Sto cercando di convertire un DWG con layer scritti in russo in shapefile.
FME Data inspector mi mostra i testi in cirillico, mentre l'esportazione in SHP mi sostituisce tutti i caratteri con punti di domanda.
Ho provato a usare tutte le combinazioni possibili con lo strumento AttributeEncoder senza risultati
Best answer by lenaatsafe
Ciao @pdorio
per favore usa Google Translate per tradurre la mia risposta in quanto non posso scrivere in italiano :)
Do you have Russian DWG layer names or Russian attribute values? Are you on Windows or Linux/Mac?
If you have Russian DWG layer names, you need to set your system locale to Russian(Russia). At the moment, FME only supports characters supported by system default encoding in dataset/feature type/attribute names. I.e. you need to have Win-1251 as your system default encoding (you most likely have Win-1252 now).
If Russian characters are in attribute values, please make sure your Shape Writer Character Encoding parameter is set to Windows Cyrillic (no need to change system locale in this case):
  • Jul 6, 2018 6:27 PM UTC
Ciao @pdorio
pdorio
  • Jul 9, 2018 6:12 AM UTC
Thank you very much!!! It works!
Regards
