Encoding multiple zipfile
  • Mar 6, 2020 11:38 AM UTC
  • 90 views
arthur_bazin
Forum|alt.badge.img+19
Hello,
I have a trouble with zipfiles.
I made a script that take multiple files and put them into a PostgreSQL database (in a binary column).
My script works really great : I'm using a datafile reader to get files and the PostgreSQL writter put them into my DB without any problems.
Where it doesn't work : when I try to import zip files, FME try to unzip them.
I don't want them to be unzipped, I want them to be imported as zip files directly into the DB.
Have you any solution ?
Thank you for your answer.
Best regards.
Arthur Bazin
Best answer by debbiatsafe
Hi @savoierider
I would recommend taking a look at the AttributeFileReader transformer for zip files instead of using the Data File reader.
I tested with a sample zip file and the AttributeFileReader created an attribute containing a value that starts the hexadecimal value 504B0304. This matches with the file signature for .zip files listed on this page: https://en.wikipedia.org/wiki/List_of_file_signatures
arthur_bazin
  • Mar 16, 2020 9:12 AM UTC
No one ever had this trouble or a solution ?
debbiatsafe
Forum|alt.badge.img+24
  • Mar 16, 2020 7:05 PM UTC
Hi @savoierider
arthur_bazin
  • Mar 20, 2020 2:14 PM UTC
Hi @debbiatsafe,
Thanks for your answer but it was only part of the solution. But my question was not complete :-)
After a lot of research, I find how to do what I want :
First, get a Directory and File Pathnames Reader with the option "Single Merged Feature Type".
Then using the AttributeFileReader.
Ok, it look really simple and easy but I don't know why, sometimes (on other projects) the Directory and File Pathnames Reader open zip files and lists all files that are in. I think it comes from parameters of the Reader but I can not find exactly witch parameter. But nevermind, it works and that's the goal...
Thank's
