we have WS running with no encoding issue on the desktop, when published on the server and used as API we are getting a result with encoding issue
we did add an ecoder into the WS , but it didnt solve the problem
Any idea, please
What's the data source here? The more details, the better.
Hi @boubcher
I agree with @david_r
More information is necessary in this case.
Thanks,
Danilo
Hello Guys
Thanks for your replay we fixe problem by setting the encoding parameter into the writer
Hello Guys
Great to hear that you found the solution, it's always a good idea to explicitely specify the encoding and utf-8 is the one to use for JSON.
Just a heads-up: you should not include the byte-order marker (BOM) when writing JSON, some applications may not like it as it's forbidden by the json standard:
Implementations MUST NOT add a byte order mark to the beginning of a JSON text.
Hello Guys
Hi @boubcher
great news!
