encoding issue when published on server
  • Sep 10, 2018 9:13 AM UTC
  • 6 replies
  • 62 views
boubcher
Forum|alt.badge.img+11
we have WS running with no encoding issue on the desktop, when published on the server and used as API we are getting a result with encoding issue
we did add an ecoder into the WS , but it didnt solve the problem
Any idea, please
Best answer by boubcher
Hello Guys
Thanks for your replay we fixe problem by setting the encoding parameter into the writer
  • Sep 10, 2018 1:43 PM UTC
What's the data source here? The more details, the better.
danilo_fme
Forum|alt.badge.img+58
  • Sep 10, 2018 2:36 PM UTC
Hi @boubcher
I agree with @david_r
More information is necessary in this case.
Thanks,
Danilo
boubcher
  • Sep 12, 2018 8:26 AM UTC
Hello Guys
boubcher
Hello Guys
  • Sep 12, 2018 8:35 AM UTC
Great to hear that you found the solution, it's always a good idea to explicitely specify the encoding and utf-8 is the one to use for JSON.
Just a heads-up: you should not include the byte-order marker (BOM) when writing JSON, some applications may not like it as it's forbidden by the json standard:
Implementations MUST NOT add a byte order mark to the beginning of a JSON text.
danilo_fme
  • Sep 12, 2018 12:43 PM UTC
Hello Guys
Hi @boubcher
great news!
