Empty string, but still not empty !
  • Jul 7, 2019 2:34 PM UTC
  • 5 replies
  • 284 views
harmen_kampinga
I have tested some attributes of a Shapefile which are empty, with a StringLenghtCalculator and those empty fields returned a value of 254 characters. That's weird. I have tried to replace those empty values with '0' or with 'EMPTY' using the NullAtributeMapper with all options and with the StringReplacer using this regular expression: [^a-zA-Z\\d\\w,.\\-/\\s/+_\\\\]
All with no success.... still the attribute value seems to have 254 characters
A familiar problem to someone? And maybe there is a solution?
harmen_kampinga
Of course, I can use the AttributeManager and then for every Attribute having that issue creating a new Attribute with a slightly different name using a condition to set the value, but that's not what I want...
The condition would like to be:
@StringLength(@Value(FIELDNAME)) = 254
And in that case, give it a default value.
And if it is not 254 characters, then add the value of the 'wrong' Attribute.
But if there are 254 characters representing a right string or value, then this condition doesn't make sense.
  • Jul 7, 2019 2:44 PM UTC
I guess that the field has been filled with 254 spaces. Try removing all spaces from the attribute value with the AttributeTrimmer.
harmen_kampinga
Thanks @takashi for your reply, but unfortunately that doesn't work... inspecting the value of the Shapefile doesn't come up with anything. It's empty/empty so to say. But in FME not recognized as a NULL, Missing Value, or whatever so far...
  • Jul 7, 2019 2:54 PM UTC
Is the length of the attribute value still 254 after trimming?
Hi @harmen1,
I stumbled across this post whilst researching a similar issue and hopefully have some answers for you.
If you use an AttributeEncoder on these attributes and set the Destination Encoding to binary does this return a value of 254 zeros? These represent null bytes, these are not printable which is why in a logger or inspector the attribute value looks like an empty string but, as proved by the StringLengthCalculator in fact it is not - which is why your NullAttributeMapper is not working as expected.
Perhaps you could use the Attribute Encoder Output to fix these - as if they do contain a true value the output will be different so you can use that in your test condition rather than the string length.
