Dynamically generated xpath in XMLUpdater is not correct
  • Aug 19, 2018 8:10 AM UTC
  • 70 views
friesewoudloper
Participant
With XMLUpdater I am changing values in an XML-file. I'd like to generate the xpath dynamically based upon a column ('Attribuut') in an Excel file. However, when I select this attribute in the text editor for the XML Path, the generated code is wrong. It is:
//*:featureAttribute[*:name/text() = 'fme:get-attribute("Attribuut")']/*:definition
where it should be:
//*:featureAttribute[*:name/text() = '@Value(Attribuut)']/*:definition
I can change this myself and everything works fine, but I'm just curious: Is this a bug, or does FME generate the xpath as one might expect? Is it something I do wrong?
Best answer by takashi
In XQuery expressions, you should not quote an XQuery function call. Try this one.
//*:featureAttribute[*:name/text() = fme:get-attribute("Attribuut")]/*:definition
The "@Value" is an FME function, which will be replaced with specified attribute value before the XQuery expression is evaluated.
  • Aug 19, 2018 12:44 PM UTC
friesewoudloper
Participant
Thank you again @takashi!
