dynamic changedetector - to loop or not to loop?
  • Feb 26, 2019 12:12 PM UTC
  • 139 views
oliver.morris
Forum|alt.badge.img+14
Hi started to use the new changedetector to identify changes between data stored in a database in sqlserver spatials versus a postgres SDE. I initially started doing it for each table but there are aroun 60 so quickly lost the will to continue.
I worked up the following dynamic tool:
At the moment it only works one feature at a time (currently I am just loading the table name in the first attribute creator.
My question is how should I run this for more that one table at a time. Will it work by passing a list of features to the feature readers or should I basically add this into a loop and just run one at a time through the loop.
I really welcome your recommendations.
Thank you
Oliver
Forum|alt.badge.img+54
  • Feb 26, 2019 1:15 PM UTC
Set your attributecreator so that feature is set from a parameter, then set up a second workspace with a workspace runner to run the change workspace once for each table.
oliver.morris
  • Feb 26, 2019 1:40 PM UTC
perfect, with give that a go.
