Dynamic attributes based on a json message.
  • Mar 11, 2022 9:16 AM UTC
  • 93 views
jdandriessen
Forum|alt.badge.img+4
The workspaces receives a JSON message with information about the columns & geometry (where the user is interested in).
fme1
We use the geometry in the FeatureReader (Spatial Filter) that is working fine, but the user only wants the attributes: "test1", "test2" in this example. How can i filter the feature class only to: "test1" & "test2". And how can i make this dynamic because it is every time different (attributes)?
The output is an excel file.
fme2
thank you.
hkingsbury
Forum|alt.badge.img+73
  • Mar 13, 2022 6:38 PM UTC
Have a look at the SchemaSetter transformer. This will generate a schema on each feature (as a list). you can then break that schema down, keep the attributes specified in the JSON, and then set the output writer to dynamic so it uses the updated schema.
https://community.safe.com/s/article/dynamic-workflow-tutorial-introduction
