Dynamic attributes and find values
  • March 17, 2016
  • 5 replies
  • 128 views
I have attributes in this fashion (simplified to make sense)
Attribute: Value
Fruit: Apple
DesiredColor:Red
Color_Of_Fruit:Green
Return_Value: IloveLeaf
Color{1}_Of_Fruit: Yellow
Return{1}_Value:IloveBanana
Color{2}_Of_Fruit: Red
Return{2}_Value:ILoveStrawberries
Note that I don't know in advance the number of occurrence of Color{x}_Of_Fruit and the corresponding Return{x}_Value. However, x should be less than 10. Also, this is not a list. This is how I get data when parsed by JXL.
What I want to do is I want to find the return{x}_Value where the value of DesiredColor matches the value of the Color{x}_Of_Fruit.
So in this example, I would return like a match on IloveStrawberries
Any ideas on how to accomplish this in an elegant fashion?
Best answer by jdh
Interestingly enough the ListSearcher can handle a list in the form of x{}_y, but the ListIndexer doesn't.
Attached is a quick and dirty transform of the attributes into an fme list and then a list searcher and list indexer
jxl-list.fmw
jdh
Forum|alt.badge.img+41
  • March 17, 2016
jxl-list.fmw
mark2atsafe
Forum|alt.badge.img+59
  • March 18, 2016
I think @jdh's solution is probably easiest.
The other way I would investigate is to set up a custom transformer loop with a loopcount attribute. Then run a Tester to see if DesiredColor = Color{loopcount}_Of_Fruit
You'd need to experiment in the Tester to get the exact syntax on the right hand side. Probably:
@Value(Color{@Value(loopcount)}_Of_Fruit)
Hope this helps
Mark
jdh
  • March 18, 2016
Hope this helps
Mark
You would still need to rename the first two attributes to match the rest, or test for them separately in the first iteration of the loop
mark2atsafe
  • March 18, 2016
In fact, thinking about it, an easier method (with two variations) would be:
- Use a TestFilter with 10 comparisons.
- Use an AttributeManager with 10 conditional values
Not elegant, but no looping and no worries about lists or @Value() syntax
  • March 18, 2016
Thank you JDH and Mark for your prompt replies! I am going to try with listindexer and see how it turns out.
